本例实验的LED模块:
电原理图(红点处D5为可控制LED)
【花雕动手做】实验六十:串口输出十六进制与字符串,语音控制继电器与彩屏
- #include "HardwareSerial.h"
- uint8_t mylist[10]={0,1,2,3,4,5,6,7,8,9};
- String ss;
- Serial.println("LED ON");
- Serial.println("LED OFF");
- digitalWrite(28,1);
- Serial.write(0xFF);
- Serial.write(0x02);
- Serial.write(0x01);
- Serial.write(0x0D);
- Serial.write(0x0A);
- case 4:
- digitalWrite(28,0);
- Serial.write(0x00);
- case 5:
- digitalWrite(21,1);
- for (int i = 0; i < 9; i = i + 1) {
- Serial.write(mylist[(int)(i)]);
- case 6:
- digitalWrite(21,0);
- Serial.println(ss);
- ss = "hello word";
- //{speak:娇娇-邻家女声,vol:16,speed:10,platform:haohaodada}
- //{ID:1,keyword:"命令词",ASR:"打开板载灯",ASRTO:"好的,马上打开灯光"}
- //{ID:2,keyword:"命令词",ASR:"关闭板载灯",ASRTO:"好的,马上关闭灯光"}
- //{ID:3,keyword:"命令词",ASR:"打开继电器",ASRTO:"好的,马上打开继电器"}
- //{ID:4,keyword:"命令词",ASR:"关闭继电器",ASRTO:"好的,马上关闭继电器"}
- //{ID:5,keyword:"命令词",ASR:"打开彩屏背光",ASRTO:"好的马上执行"}
- //{ID:6,keyword:"命令词",ASR:"关闭彩屏背光",ASRTO:"好的马上执行"}
- pinMode(21,output);
- setPinFun(21,SECOND_FUNCTION);
- pinMode(28,output);
- setPinFun(28,FIRST_FUNCTION);
- Serial.begin(9600);
- setPinFun(13,SECOND_FUNCTION);
- setPinFun(14,SECOND_FUNCTION);
实验串口返回情况
串口输出截图
