楼主 |
发表于 2023-11-13 17:05:43
显示全部楼层
【花雕动手做】实验十一:通过语音控制1.77寸彩屏显示不同图形
- int8_t volue = 5;
- //{ID:500,keyword:"唤醒词",ASR:"智能管家",ASRTO:"我在呢"}
- //{ID:501,keyword:"命令词",ASR:"不错啊",ASRTO:"谢谢,更多精彩在后面"}
- //{ID:502,keyword:"命令词",ASR:"画个红点",ASRTO:"有了"}
- spi_tft.draw_point(64,80,(0xF800));
- //{ID:503,keyword:"命令词",ASR:"蓝色背景",ASRTO:"可以了"}
- //{ID:504,keyword:"命令词",ASR:"打开屏幕",ASRTO:"好的"}
- //{ID:505,keyword:"命令词",ASR:"空心圆",ASRTO:"当中没有"}
- spi_tft.draw_circle(50,50,50,(0xF800));
- //{ID:506,keyword:"命令词",ASR:"三角形",ASRTO:"绿色的"}
- spi_tft.fill_triangle(10,123,55,10,110,155,(0x07E0));
- //{ID:507,keyword:"命令词",ASR:"实心圆",ASRTO:"填满了"}
- if(snid == 507){
- spi_tft.fill_circle(50,50,50,(0xF800));
- //{ID:508,keyword:"命令词",ASR:"画条直线",ASRTO:"红色的"}
- if(snid == 508){
- spi_tft.draw_line(0,80,128,80,(0xF800));
- //{ID:509,keyword:"命令词",ASR:"画条竖线",ASRTO:"绿色的"}
- if(snid == 509){
- spi_tft.draw_line(64,0,64,160,(0x07E0));
- //{ID:510,keyword:"命令词",ASR:"空心矩形",ASRTO:"蓝色的"}
- if(snid == 510){
- spi_tft.draw_rectangle(13,12,99,130,(0x001F));
- //{ID:511,keyword:"命令词",ASR:"两条蓝线",ASRTO:"交叉了"}
- if(snid == 511){
- spi_tft.draw_line(0,0,128,160,(0x001F));
- spi_tft.draw_line(0,160,128,0,(0x001F));
- //{ID:512,keyword:"命令词",ASR:"实心矩形",ASRTO:"还是蓝色"}
- if(snid == 512){
- spi_tft.fill_rectangle(13,12,99,130,(0x001F));
- //{speak:小美-娇美女声,vol:20,speed:10,platform:haohaodada}
- //{playid:10002,voice:我要退下了,用智能管家唤醒我}
天问Block(标准模式)训练模型与编译烧录
https://www.bilibili.com/video/BV1tb4y1g7G3/?share_source=copy_web&vd_source=371a292a55e5ca9be994cbb4a86cc987
