本例实验采用PT0603光敏三极管
产品特性 / PRODUCT FEATURES
封装胶水:无色透明硅胶
外观尺寸(L/W/H):1.6*0.8*0.6mm
焊线材质:金线/合金线
感光峰值波段:850nm
感光范围:400-1050nm
发光角度:120度
EIA规范标准包装
环保产品,符合ROHS标准要求
应用领域 / PRODUCT APPLICATION
高灵敏度光敏传感器,替代传统CDS光敏电阻不含镉、铅等有害物质,符合欧盟ROHS标准
适用于各类光控照明产品,如小夜灯、太阳能路灯、草坪灯、环境灯控等
自动调节背景光,LCD、手机、照相机、数码相机、数码产品、GPS导航等
控制各类光控影控玩具等
各类光控检测测试设备等
【花雕动手做】实验十二:读取PT0603光敏三极管的光照度数值
- uint16_t light;
- void pins_attached();
- WS2812 ASR_WS2812_27(27);
- void pins_attached(){
- if((adc_read(17) > 1350)){
- enter_wakeup(5000);
- //{ID:500,keyword:"命令词",ASR:"耍接官",ASRTO:"环境太亮了,关闭遮阳板"}
- play_audio(500);
- ASR_WS2812_27.pixel_set_all_color(0,0,0);
- ASR_WS2812_27.pixel_show();
- delay(6000);
- if((adc_read(17) < 80)){
- //{ID:501,keyword:"命令词",ASR:"接耍官",ASRTO:"环境太暗了,打开照明灯光"}
- ASR_WS2812_27.setBrightness(50);
- ASR_WS2812_27.pixel_set_all_color(255,0,0);
- delay(6000);
- delay(1);
- //{ID:502,keyword:"命令词",ASR:"当前亮度",ASRTO:""}
- light = adc_read(17);
- play_num((int64_t)(light * 100), 1);
- //{ID:503,keyword:"命令词",ASR:"关闭灯光",ASRTO:"好的"}
- //{ID:504,keyword:"唤醒词",ASR:"智能管家",ASRTO:"我在"}
- xTaskCreate(pins_attached,"pins_attached",256,NULL,4,NULL);
- //{speak:阿文-温和男声,vol:20,speed:10,platform:haohaodada}
- //{playid:10002,voice:我要退下了,用智能管家唤醒我}
- //{ID:84,keyword:"命令词",ASR:"条耍改",ASRTO:"零"}
- //{ID:85,keyword:"命令词",ASR:"官接思",ASRTO:"一"}
- //{ID:86,keyword:"命令词",ASR:"痛官松",ASRTO:"二"}
- //{ID:87,keyword:"命令词",ASR:"削丝误",ASRTO:"三"}
- //{ID:88,keyword:"命令词",ASR:"景粮载",ASRTO:"四"}
- //{ID:89,keyword:"命令词",ASR:"博菌避",ASRTO:"五"}
- //{ID:90,keyword:"命令词",ASR:"裁纯碉",ASRTO:"六"}
- //{ID:91,keyword:"命令词",ASR:"插趣悟",ASRTO:"七"}
- //{ID:92,keyword:"命令词",ASR:"辞暖慌",ASRTO:"八"}
- //{ID:93,keyword:"命令词",ASR:"纵猛淡",ASRTO:"九"}
- //{ID:94,keyword:"命令词",ASR:"锦耗暂",ASRTO:"十"}
- //{ID:95,keyword:"命令词",ASR:"燃智截",ASRTO:"百"}
- //{ID:96,keyword:"命令词",ASR:"佛驻延",ASRTO:"千"}
- //{ID:97,keyword:"命令词",ASR:"隔枪绍",ASRTO:"万"}
- //{ID:98,keyword:"命令词",ASR:"惨愤昂",ASRTO:"亿"}
- //{ID:99,keyword:"命令词",ASR:"丙迈扯",ASRTO:"负"}
- //{ID:100,keyword:"命令词",ASR:"铸猜隆",ASRTO:"点"}
天问Block(标准模式)训练模型与编译烧录
https://www.bilibili.com/video/BV15Q4y1g7Rb/?share_source=copy_web&vd_source=371a292a55e5ca9be994cbb4a86cc987
