SPI彩色液晶显示屏:TFT177-SPI,型号为SX177QQVGA,像素128X160TFT,驱动芯片为ST7735S,这是一款支持SPI接口的1.77寸TFT彩屏,可以显示文字、图形、图片等内容,提高用户互动体验度。
【花雕动手做】实验十八:用1.8寸TFT彩屏(ST7735)显示大号汉字与变换字号
- int8_t volue = 5;
- WS2812 ASR_WS2812_27(27);
- //{ID:500,keyword:"唤醒词",ASR:"智能管家",ASRTO:"我在"}
- ASR_WS2812_27.pixel_show();
- //{ID:501,keyword:"命令词",ASR:"蓝色背景",ASRTO:"可以了"}
- ASR_WS2812_27.setBrightness(50);
- ASR_WS2812_27.pixel_set_all_color(0,0,255);
- //{ID:502,keyword:"命令词",ASR:"人工智能",ASRTO:"已显示"}
- spi_tft.set_cursor(15,40);
- spi_tft.draw_hanzi_24("人工智能");
- //{ID:503,keyword:"命令词",ASR:"显示内容",ASRTO:"人工智能语音识别"}
- //{ID:504,keyword:"命令词",ASR:"语音识别",ASRTO:"有了"}
- spi_tft.set_cursor(0,90);
- spi_tft.draw_hanzi_32("语音识别");
- //{ID:505,keyword:"命令词",ASR:"不错呀",ASRTO:"这个鼓励很到位,谢谢!"}
- //{ID:506,keyword:"命令词",ASR:"连起来",ASRTO:""}
- spi_tft.set_cursor(15,90);
- spi_tft.draw_hanzi_24("语音识别");
- delay(500);
- spi_tft.set_cursor(0,40);
- spi_tft.draw_hanzi_32("人工智能");
- //{ID:507,keyword:"命令词",ASR:"红色背景",ASRTO:"可以了"}
- if(snid == 507){
- ASR_WS2812_27.pixel_set_all_color(0,0,0);
- spi_tft.set_text_size(12);
- //{speak:欢欢-职业女声,vol:20,speed:10,platform:haohaodada}
【【花雕动手做】实验十八:用1.8寸TFT彩屏(ST7735)显示大号汉字与变换字号】 https://www.bilibili.com/video/BV1hK411b7e4/?share_source=copy_web&vd_source=371a292a55e5ca9be994cbb4a86cc987
