查看: 486|回复: 0
【花雕动手做】ASRPRO语音识别(17)---按键控制彩屏和继电器
发表于 2023-12-26 22:25:39 | 显示全部楼层 |阅读模式
本例实验采用板载三位独立按键,可以搭配实现各种相关的功能。
【花雕动手做】实验二十二:使用按键和语音控制1.8寸彩屏与继电器的开关
  4. #include "myLib/asr_event.h"
  5. uint32_t snid;
  6. void ASR_CODE();
  7. void hardware_init();
  8. /*描述该功能...
  9. */
  10. void ASR_CODE(){
  11.   switch (snid) {
  12.    case 3:
  13.     digitalWrite(28,1);
  14.     break;
  15.    case 4:
  16.     digitalWrite(28,0);
  17.     break;
  18.    case 5:
  19.     digitalWrite(21,1);
  20.     break;
  21.    case 6:
  22.     digitalWrite(21,0);
  23.     break;
  24.   }
  25. }
  26. //{ID:250,keyword:"命令词",ASR:"最大音量",ASRTO:"音量调整到最大"}
  27. //{ID:251,keyword:"命令词",ASR:"中等音量",ASRTO:"音量调整到中等"}
  28. //{ID:252,keyword:"命令词",ASR:"最小音量",ASRTO:"音量调整到最小"}
  29. void hardware_init(){
  30.   pinMode(4,input);
  31.   setPinFun(4,FIRST_FUNCTION);
  32.   pinMode(18,input);
  33.   dpmu_set_adio_reuse(PC2,DIGITAL_MODE);
  34.   dpmu_set_io_pull(pinToFun[18],DPMU_IO_PULL_UP);
  35.   setPinFun(18,SECOND_FUNCTION);
  36.   pinMode(19,input);
  37.   dpmu_set_adio_reuse(PC3,DIGITAL_MODE);
  38.   dpmu_set_io_pull(pinToFun[19],DPMU_IO_PULL_UP);
  39.   setPinFun(19,SECOND_FUNCTION);
  40.   while (1) {
  41.     if(!(digitalRead(4))){
  42.       digitalWrite(28,0);
  43.       digitalWrite(21,0);
  44.       delay(200);
  45.       enter_wakeup(5000);
  46.       delay(200);
  47.       //{ID:500,keyword:"命令词",ASR:"耍接官",ASRTO:"关闭所有"}
  48.       play_audio(500);
  49.     }
  50.     if(!(digitalRead(19))){
  51.       digitalWrite(28,1);
  52.       delay(200);
  53.       enter_wakeup(5000);
  54.       delay(200);
  55.       //{ID:501,keyword:"命令词",ASR:"接耍官",ASRTO:"打开继电器"}
  56.       play_audio(501);
  57.     }
  58.     if(!(digitalRead(18))){
  59.       digitalWrite(21,1);
  60.       delay(200);
  61.       enter_wakeup(5000);
  62.       delay(200);
  63.       //{ID:502,keyword:"命令词",ASR:"官耍接",ASRTO:"打开彩屏背光"}
  64.       play_audio(502);
  65.     }
  66.     delay(100);
  67.   }
  68.   vTaskDelete(NULL);
  69. }
  70. void setup()
  71. {
  72.   //{speak:小伦-日常,vol:18,speed:10,platform:haohaodada,version:V3}
  73.   //{playid:10001,voice:欢迎使用人工智能AI语音助手,用智能管家唤醒我}
  74.   //{playid:10002,voice:我退下了,用智能管家唤醒我}
  75.   //{ID:0,keyword:"唤醒词",ASR:"智能管家",ASRTO:"我在"}
  76.   //{ID:3,keyword:"命令词",ASR:"打开继电器",ASRTO:"好的,马上打开继电器"}
  77.   //{ID:4,keyword:"命令词",ASR:"关闭继电器",ASRTO:"好的,马上关闭继电器"}
  78.   //{ID:5,keyword:"命令词",ASR:"打开彩屏背光",ASRTO:"好的马上执行"}
  79.   //{ID:6,keyword:"命令词",ASR:"关闭彩屏背光",ASRTO:"好的马上执行"}
  80.   pinMode(28,output);
  81.   setPinFun(28,FIRST_FUNCTION);
  82.   pinMode(21,output);
  83.   setPinFun(21,SECOND_FUNCTION);
  84.   xTaskCreate(hardware_init,"hardware_init",256,NULL,100,NULL);
  85. }
【【花雕动手做】实验二十二:使用按键和语音控制1.8寸彩屏与继电器的开关】
https://www.bilibili.com/video/BV1ap4y1d77e/?share_source=copy_web&vd_source=371a292a55e5ca9be994cbb4a86cc987
GMT+8, 2024-7-28 04:21 , Processed in 0.117039 second(s), 26 queries .
