本例实验采用板载三位独立按键,可以搭配实现各种相关的功能。
【花雕动手做】实验二十三:使用按键和语音控制1.8寸彩屏转换颜色与汉字
- case 0:
- digitalWrite(21,1);
- spi_tft.set_cursor(0,50);
- spi_tft.draw_hanzi_32("红色屏幕");
- spi_tft.draw_hanzi_32("蓝色屏幕");
- spi_tft.clear((0x07E0));
- spi_tft.set_text_color((0xFFFF),(0x07E0));
- spi_tft.draw_hanzi_32("绿色屏幕");
- spi_tft.set_text_size(12);
- pinMode(4,input);
- pinMode(18,input);
- dpmu_set_adio_reuse(PC2,DIGITAL_MODE);
- dpmu_set_io_pull(pinToFun[18],DPMU_IO_PULL_UP);
- setPinFun(18,SECOND_FUNCTION);
- pinMode(19,input);
- dpmu_set_adio_reuse(PC3,DIGITAL_MODE);
- dpmu_set_io_pull(pinToFun[19],DPMU_IO_PULL_UP);
- setPinFun(19,SECOND_FUNCTION);
- if(!(digitalRead(4))){
- enter_wakeup(5000);
- //{ID:500,keyword:"命令词",ASR:"耍接官",ASRTO:"绿色"}
- play_audio(500);
- if(!(digitalRead(19))){
- //{ID:501,keyword:"命令词",ASR:"接耍官",ASRTO:"蓝色"}
- if(!(digitalRead(18))){
- //{ID:502,keyword:"命令词",ASR:"官耍接",ASRTO:"红色"}
- play_audio(502);
- delay(100);
- //{speak:小英-日常,vol:18,speed:10,platform:haohaodada,version:V3}
- //{ID:1,keyword:"命令词",ASR:"屏幕红色",ASRTO:"好的,红了"}
- //{ID:2,keyword:"命令词",ASR:"屏幕蓝色",ASRTO:"好的,蓝了"}
- //{ID:3,keyword:"命令词",ASR:"屏幕绿色",ASRTO:"好的,绿了"}
- //{ID:4,keyword:"命令词",ASR:"不错不错",ASRTO:"谢谢鼓励哦"}
【【花雕动手做】实验二十三:使用按键和语音控制1.8寸彩屏转换颜色与汉字】 https://www.bilibili.com/video/BV1CN4y1s7nb/?share_source=copy_web&vd_source=371a292a55e5ca9be994cbb4a86cc987
