本例实验采用板载三位独立按键,可以搭配实现各种相关的功能。
【花雕动手做】实验二十四:使用按键和语音分别控制继电器的开与关
- void pins_attached();
- void pins_attached(){
- if((digital_read((18)) == 0)){
- digital_write((28),1);
- enter_wakeup(5000);
- //{ID:500,keyword:"命令词",ASR:"耍接官",ASRTO:"按键控制继电器打开"}
- play_audio(500);
- spi_tft.set_cursor(5,70);
- spi_tft.draw_hanzi_24("继电器打开");
- if((digital_read((4)) == 0)){
- digital_write((28),0);
- //{ID:501,keyword:"命令词",ASR:"接耍官",ASRTO:"按键控制继电器关闭"}
- spi_tft.draw_hanzi_24("继电器关闭");
- delay(1);
- //{ID:502,keyword:"命令词",ASR:"反应挺快",ASRTO:"那是必须的"}
- //{ID:503,keyword:"唤醒词",ASR:"智能管家",ASRTO:"我在"}
- //{ID:504,keyword:"命令词",ASR:"打开继电器",ASRTO:"语音控制继电器打开"}
- spi_tft.set_cursor(0,30);
- spi_tft.draw_hanzi_32("语音控制");
- delay(1000);
- //{ID:505,keyword:"命令词",ASR:"关闭继电器",ASRTO:"语音控制继电器关闭"}
- delay(1000);
- xTaskCreate(pins_attached,"pins_attached",256,NULL,4,NULL);
- //{speak:小英-温和,vol:10,speed:10,platform:haohaodada,version:V3}
- digital_write((19),1);
- set_gpio_input((18));
- set_gpio_input((4));
【【花雕动手做】ASRPRO语音识别(19)---语音和按键控制继电器】
https://www.bilibili.com/video/BV1Y5411B7HQ/?share_source=copy_web&vd_source=371a292a55e5ca9be994cbb4a86cc987
