本例实验采用PT0603光敏三极管
产品特性 / PRODUCT FEATURES
封装胶水:无色透明硅胶
外观尺寸(L/W/H):1.6*0.8*0.6mm
焊线材质:金线/合金线
感光峰值波段:850nm
感光范围:400-1050nm
发光角度:120度
EIA规范标准包装
环保产品,符合ROHS标准要求
【花雕动手做】实验二十九:PT0603光敏三极管检测环境亮度控制ST7735彩屏
- uint16_t liangdu;
- void pins_attached();
- WS2812 ASR_WS2812_27(27);
- void pins_attached(){
- if((adc_read(17) < 300)){
- enter_wakeup(3000);
- spi_tft.set_cursor(0,30);
- spi_tft.draw_hanzi_32("光照度为");
- //{ID:500,keyword:"命令词",ASR:"耍接官",ASRTO:"光照度为"}
- play_audio(500);
- delay(800);
- liangdu = adc_read(17);
- play_num((int64_t)(liangdu * 100), 1);
- spi_tft.set_cursor(35,65);
- spi_tft.println((String(liangdu)));
- delay(800);
- spi_tft.set_cursor(15,100);
- //{ID:501,keyword:"命令词",ASR:"接耍官",ASRTO:"天黑了,关门睡觉吧"}
- spi_tft.draw_hanzi_24("天黑睡觉");
- delay(7000);
- delay(1);
- //{ID:502,keyword:"唤醒词",ASR:"当前亮度",ASRTO:"开始测量"}
- ASR_WS2812_27.pixel_set_all_color(255,0,0);
- ASR_WS2812_27.pixel_show();
- delay(800);
- spi_tft.set_cursor(0,40);
- spi_tft.draw_hanzi_32("环境亮度");
- delay(800);
- spi_tft.set_cursor(35,80);
- //{ID:503,keyword:"命令词",ASR:"官耍接",ASRTO:"环境亮度"}
- play_audio(503);
- delay(800);
- //{ID:504,keyword:"唤醒词",ASR:"智能管家",ASRTO:"我在"}
- delay(800);
- spi_tft.set_cursor(15,40);
- spi_tft.draw_hanzi_24("有什么事");
- delay(800);
- spi_tft.set_cursor(28,80);
- spi_tft.draw_hanzi_24("请吩咐");
- //{ID:505,keyword:"命令词",ASR:"效果不错",ASRTO:"有你的鼓励真好,谢谢啦!"}
- xTaskCreate(pins_attached,"pins_attached",256,NULL,4,NULL);
- //{speak:小美-娇美女声,vol:20,speed:10,platform:haohaodada}
- //{ID:84,keyword:"命令词",ASR:"条耍改",ASRTO:"零"}
- //{ID:85,keyword:"命令词",ASR:"官接思",ASRTO:"一"}
- //{ID:86,keyword:"命令词",ASR:"痛官松",ASRTO:"二"}
- //{ID:87,keyword:"命令词",ASR:"削丝误",ASRTO:"三"}
- //{ID:88,keyword:"命令词",ASR:"景粮载",ASRTO:"四"}
- //{ID:89,keyword:"命令词",ASR:"博菌避",ASRTO:"五"}
- //{ID:90,keyword:"命令词",ASR:"裁纯碉",ASRTO:"六"}
- //{ID:91,keyword:"命令词",ASR:"插趣悟",ASRTO:"七"}
- //{ID:92,keyword:"命令词",ASR:"辞暖慌",ASRTO:"八"}
- //{ID:93,keyword:"命令词",ASR:"纵猛淡",ASRTO:"九"}
- //{ID:94,keyword:"命令词",ASR:"锦耗暂",ASRTO:"十"}
- //{ID:95,keyword:"命令词",ASR:"燃智截",ASRTO:"百"}
- //{ID:96,keyword:"命令词",ASR:"佛驻延",ASRTO:"千"}
- //{ID:97,keyword:"命令词",ASR:"隔枪绍",ASRTO:"万"}
- //{ID:98,keyword:"命令词",ASR:"惨愤昂",ASRTO:"亿"}
- //{ID:99,keyword:"命令词",ASR:"丙迈扯",ASRTO:"负"}
- //{ID:100,keyword:"命令词",ASR:"铸猜隆",ASRTO:"点"}
【【花雕动手做】ASRPRO语音识别(24)---PT0603光敏控制屏幕】
https://www.bilibili.com/video/BV1jt4y1Z7XS/?share_source=copy_web&vd_source=371a292a55e5ca9be994cbb4a86cc987
