本例实验采用直条八位WS2812B灯模块
主要特点:
1、5050高亮LED,内置控制芯片,仅需1个IO口即可控制多个LED模块
2、芯片内置整形电路,信号畸变不会累计,稳定显示
3、三基色256级亮度调剂,16万色真彩显示效果,扫描频率不低于400Hz/S
4、串行级联接口,能通过一根信号线完成数据的接收与解码
5、刷新速率30帧/秒时,低速连级模式连级数不小于512点
6、数据收发速度最高可达800Kbps
7、高亮LED,光色亮度一致性高
8、两端有连级接口,可以直接插接
【花雕动手做】实验四十一:随机位置三色直条8位流光溢彩WS2812B灯
- #include "asr_math.h"
- WS2812 ASR_WS2812_24(24);
- //{ID:500,keyword:"命令词",ASR:"绿色灯",ASRTO:"打开绿色灯"}
- ASR_WS2812_24.setBrightness(30);
- ASR_WS2812_24.pixel_set_all_color(0,255,0);
- ASR_WS2812_24.pixel_show();
- spi_tft.set_cursor(15,60);
- spi_tft.draw_hanzi_32("绿色灯");
- delay(800);
- //{ID:501,keyword:"命令词",ASR:"效果不错",ASRTO:"有你的鼓励真好,谢谢啦!"}
- //{ID:502,keyword:"命令词",ASR:"随机灯",ASRTO:"随机位置三色灯"}
- ASR_WS2812_24.pixel_set_color((random(0, 8+1)),255,0,0);
- ASR_WS2812_24.setBrightness(60);
- ASR_WS2812_24.pixel_set_color((random(0, 8+1)),0,0,255);
- ASR_WS2812_24.pixel_set_color((random(0, 8+1)),0,255,0);
- delay(1000);
- spi_tft.set_cursor(0,60);
- spi_tft.draw_hanzi_32("随机亮灯");
- //{ID:503,keyword:"命令词",ASR:"蓝色灯",ASRTO:"打开蓝色灯"}
- ASR_WS2812_24.setBrightness(50);
- ASR_WS2812_24.pixel_set_all_color(0,0,255);
- spi_tft.draw_hanzi_32("蓝色灯");
- delay(800);
- //{ID:504,keyword:"命令词",ASR:"流光溢彩",ASRTO:"流光溢彩灯"}
- ASR_WS2812_24.rainbow(5);
- spi_tft.draw_hanzi_32("流光溢彩");
- delay(800);
- //{ID:505,keyword:"唤醒词",ASR:"智能管家",ASRTO:"我在"}
- delay(800);
- spi_tft.set_cursor(15,40);
- spi_tft.draw_hanzi_24("有什么事");
- delay(800);
- spi_tft.set_cursor(28,80);
- spi_tft.draw_hanzi_24("请吩咐");
- //{ID:506,keyword:"命令词",ASR:"关闭所有",ASRTO:"关闭所有灯"}
- spi_tft.draw_hanzi_32("关闭所有");
- ASR_WS2812_24.pixel_set_all_color(0,0,0);
- delay(800);
- //{ID:507,keyword:"命令词",ASR:"红色灯",ASRTO:"打开红色灯"}
- if(snid == 507){
- ASR_WS2812_24.pixel_set_all_color(255,0,0);
- spi_tft.draw_hanzi_32("红色灯");
- delay(800);
- ASR_WS2812_24.pixel_init(8);
- pinMode(24,output);
- //{speak:娇娇-邻家女声,vol:12,speed:10,platform:haohaodada}
【【花雕动手做】ASRPRO语音识别(36)--流光溢彩和随机LED灯】 https://www.bilibili.com/video/BV19K411Y7jV/?share_source=copy_web&vd_source=371a292a55e5ca9be994cbb4a86cc987
