ASRPRO-Plus开发板
板子基本介绍
本例实验的LED模块:
电原理图(红点处D5为可控制LED)
【花雕动手做】实验五十六:语音控制软件定时器单次运行和重复运行
- void stimer_2(TimerHandle_t xTimer);
- TimerHandle_t softtimer_2=NULL;
- void stimer_1(TimerHandle_t xTimer);
- TimerHandle_t softtimer_1=NULL;
- xTimerStart(softtimer_1,0);
- xTimerStop(softtimer_1,0);
- digitalWrite(28,1);
- xTimerStart(softtimer_2,0);
- case 4:
- digitalWrite(28,0);
- xTimerStop(softtimer_2,0);
- void stimer_2(TimerHandle_t xTimer){
- void stimer_1(TimerHandle_t xTimer){
- digitalWrite(4,!(digitalRead(4)));
- softtimer_1=xTimerCreate("stimer_1",100,1,0,stimer_1);
- softtimer_2=xTimerCreate("stimer_2",5000,0,0,stimer_2);
- //{speak:小蝶-清新女声,vol:16,speed:10,platform:haohaodada}
- //{ID:1,keyword:"命令词",ASR:"打开灯光",ASRTO:"好的,马上打开,灯光在闪烁"}
- //{ID:2,keyword:"命令词",ASR:"关闭灯光",ASRTO:"好的,马上关闭灯光"}
- //{ID:3,keyword:"命令词",ASR:"打开继电器",ASRTO:"好的,打开继电器,继电器十秒后关闭"}
- //{ID:4,keyword:"命令词",ASR:"关闭继电器",ASRTO:"好的,马上关闭继电器"}
- pinMode(28,output);
- setPinFun(28,FIRST_FUNCTION);
