ASRPRO-Plus开发板
板子基本介绍
本例实验的LED模块:
电原理图(红点处D5为可控制LED)
【花雕动手做】实验五十八:控制板载灯、继电器与彩屏背光的串口输出显示
- #include "HardwareSerial.h"
- //根据自己的需要选择不同的串口输出
- Serial.println("LED ON");
- Serial.println("LED OFF");
- digitalWrite(28,1);
- Serial.println("RELAY ON");
- case 4:
- digitalWrite(28,0);
- Serial.println("RELAY OFF");
- case 5:
- digitalWrite(21,1);
- Serial.println("TFT ON");
- case 6:
- digitalWrite(21,0);
- Serial.println("TFT OFF");
- //{speak:小蝶-清新女声,vol:10,speed:10,platform:haohaodada}
- //{ID:1,keyword:"命令词",ASR:"打开板载灯",ASRTO:"好的,马上打开灯光"}
- //{ID:2,keyword:"命令词",ASR:"关闭板载灯",ASRTO:"好的,马上关闭灯光"}
- //{ID:3,keyword:"命令词",ASR:"打开继电器",ASRTO:"好的,马上打开继电器"}
- //{ID:4,keyword:"命令词",ASR:"关闭继电器",ASRTO:"好的,马上关闭继电器"}
- //{ID:5,keyword:"命令词",ASR:"打开彩屏背光",ASRTO:"好的马上执行"}
- //{ID:6,keyword:"命令词",ASR:"关闭彩屏背光",ASRTO:"好的马上执行"}
- pinMode(28,output);
- setPinFun(28,FIRST_FUNCTION);
- pinMode(21,output);
- setPinFun(21,SECOND_FUNCTION);
- Serial.begin(9600);
- setPinFun(13,SECOND_FUNCTION);
- setPinFun(14,SECOND_FUNCTION);
- setPinFun(15,SECOND_FUNCTION);
- setPinFun(16,SECOND_FUNCTION);
- Serial1.begin(9600);
- setPinFun(5,FORTH_FUNCTION);
- setPinFun(6,FORTH_FUNCTION);
- Serial2.begin(9600);
实验串口返回情况
