楼主 |
发表于 2024-5-28 17:12:34
显示全部楼层
右边的代码如下
- #include "HardwareSerial.h"
- #include "myLib/ESP_WIFI.h"
- ESPWIFI wifi_Serial2(&Serial2);
- void app();
- //{speak:小蝶-清新女声,vol:10,speed:10,platform:haohaodada}
- //{playid:10001,voice:}
- //{playid:10002,voice:}
- void app(){
- Serial.println((wifi_Serial2.http_get("http://www.haohaodada.com/gettime.php")));
- delay(5000);
- delay(2000);
- wifi_Serial2.begin();
- if(wifi_Serial2.check()){
- Serial.println("check ok");
- else{
- Serial.println("check err");
- delay(2000);
- if(wifi_Serial2.restore()){
- else{
- delay(2000);
- if(wifi_Serial2.setMode(WIFI_MODE_STATION)){
- Serial.println("setMode ok");
- else{
- Serial.println("setMode err");
- delay(2000);
- if(wifi_Serial2.connectAP("Turbo","12345678")){
- Serial.println("connectAP ok");
- else{
- Serial.println("connectAP err");
- delay(2000);
- xTaskCreate(app,"app",128,NULL,4,NULL);
- setPinFun(5,FORTH_FUNCTION);
- setPinFun(6,FORTH_FUNCTION);
- dpmu_set_io_pull(pinToFun[5],DPMU_IO_PULL_DISABLE);
- dpmu_set_io_pull(pinToFun[6],DPMU_IO_PULL_DISABLE);
- dpmu_set_io_open_drain(pinToFun[5],ENABLE );
- // 下载器的烧录端口
- setPinFun(13,SECOND_FUNCTION);
- setPinFun(14,SECOND_FUNCTION);
- Serial.begin(9600);
- Serial2.begin(115200);
复制代码 |
